Communicating from modsoft
Sports_
Oct 2017
British Columbia
Hey all,
I am trying to communicate with an old PLC using Modsoft.
It's a Modicon Quantam 140 113 03. I am using Modsoft and whatever I try, I
Still can't seem to connect to it. I have tried a couple different laptops using Windows XP. For cables, I've tried from the CPU from the modbus port (9-pin) to the laptop using a 9-pin, I've tried the switch to rj45, and a 9 pin to USB adapter. Still I cannot connect through Dos with Modsoft. There is a modbus plus port on the CPU I did try but don't think is correct.
I don't know if the computers are too new and the Dos isn't a full Dos addition potentially or if I am missing something obvious.
Maybe is there a program that is newer that can convert maybe?
I'm not really sure what the next move is from here.
Thanks in advance for any help at all.
Hello,
I keep an old Toshiba laptop with only MS DOS installed to run MODSOFT. Every time I attempted to run it on anything other than raw MS DOS it failed. I have read of others using MS DOS emulations with success, I was never able to duplicate. It has been a few years since I last tried. Serial port timing seemed to be the issue.
Dear All Please help me about Below picture problem.PLC not communicating proper.
181
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
695
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
455
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
361
Have a customer that has a running 1756-l83es, communicating to redundant ABCIP IO servers for Wonderware 2020. This configuration has been...
880
