Communicating from PC to ultra 3000 servo drives
DUNK
Aug 2006
south carolina
83
What type of cable do I need in order to communicate from a PC to an Ultra 3000 servo drive?? I am using Ultraware programming software.
thanks,
DUNK
It is a standard serial cable (5 pin) with pins 2,3, and 5 used. Basically, it is 5-5 and either 2-2,3-3 or 2-3, 3-2. A-B has it for sale or you could make your own with RadioShack parts.
Thanks pimpim,
I couldnt find my manual for this drive and when I tried to download it from AB my reader would crash. Seems to work well from this other pc. You have solved my problem.
Thanks Again!
Hi pimpim32 and DUNK.
I am new to communication in this type of driver, I have a question.
The cable they use is UBS to RS232 with the configuration on the pins or it has to be RS232 to RS232
Think maybe it will work
Long time since I did not use these. Even I do not remember the cable type :)
Anyway what I do remember is that usually if they say RS232-RS232 mostly this is the right configuration, and you will need a laptop with PCMCIA or even better a RS232 port to connect for sure. Good luck with that.
However a USB-RS232 might work as well, worth to give it a try. Just get a good emulator one, not a cheapo type from Ebay.
I have two AB ultra 3000i servos (2098-DSD-020X/C) with a 3-wire null modem to the PC using Ultraware Version 1.80.0.0 in Tools->Recover...
2,616
Dear All Please help me about Below picture problem.PLC not communicating proper.
188
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
724
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
474
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
373
