Configuring Bluetree/Sixnet Cellular Modem for SCADA
jols007
Jul 2008
Pennsylvania
At my control site with a standalone SCADA network I've connected a Bluetree 6621 (BT-6621 VZ) cellular modem. I have another modem here that I plan to use at a remote site once I confirm it's properly configured and the ethernet connected RTU can be polled.
I assigned both modems LAN IPs similar to our current network and to eliminate network switches, routers, etc as part of the problem...I have bypassed all of them and simply connected the host cell modem to a Windows 7 PC via ethernet. I am able to do the following: a) ping the LAN of whichever modem is plugged into the PC b) open up a telnet session to whichever modem is plugged into the PC and successfully ping (via at+bpingh command) the other modem's WAN address wirelessly.
Some other information: Verizon set up a restricted IP connection for me with static IPs. All that I know about what this means is that I can't just open up a browser from any device connected to the internet and access these modems. I'm not sure if this "IP restriction" is causing me issues? Verizon recommended I only use a remote modem accessible to the internet and simply hop over the firewall to enter my SCADA systems private network. Given the severity of the work at hand, I decided that method was not secure enough so I chose to setup the M2M (machine to machine) method that I described above.
Does anyone have any ideas here? I would think pinging the remote modem's LAN IP from the host modem/PC and thus any device behind the modem is what I'm looking for, that way I can start sending/receiving remote signals to/from the host site. I contacted VZW to see if there were any ports being blocked and they said no. If I daisy chain the modems via ethernet cables I can ping the remote unit, I would expect Verizon's wireless piece would act the same.
I have a detailed sketch if anyone nice enough to help would like to see it. Thanks!
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
776
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
588
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
658
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,148
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,269
