configuring DXP remote I/O terminals
unsaint32
Oct 2012
minneapolis
365
Turck Fen20 16DXP. It's a remote I/O. Lately I see these DXP modules where its terminals can be used as either input or output. I scoured Fen20 16DXP manual and I cannot find info about how to configure the terminals for either input or output. Using Turck software?
Best as I can tell, the inputs and outputs are not configurable, though I just scanned the manual real quick:
http://old.turck.us/illustrations/FEN20_Quick_Start_Guide.pdf
No, but I wanted to know that we were talking in the same "neighborhood".
Its funny you posted this as I'm working with a Turck FDN20-16XSG for the first time today and its configurable outputs work very strange, at least to me.
The manual states that i/o points self-configure to inputs or outputs depending on what you write to them in the output map. If you want an i/o point to be used as an output, PLC writes a one to the map, the point becomes an output and turns on. If a zero is written, its output circuit goes off and it can then be used as an input again. I believe the module you are using works the same. First time I've used these so it was strange.
would you send me a link to the manual for FDN20-16XSG? Thanks.
Hi, can you help me out here, I am trying to figure out how to do the same thing here (how to set the terminals either as input or outputs). I am a PLC novice. So, I don't understand the concep tof "write to them in the output map." What do you mean by "map?" What do you mean by "Write to them?" I am guessing, I add the DXP module to my Controlloigx in my ACD project (in Rslogix5k), then I can write 1 or 0 on to the corresponding tag? Thank you in advance.
See page 2 of the link I provided in my previous post. the I/O mapping describes what you see when you open your controller tags on the device and how they work. Beyond that, I would suggest you seek out someone with experience that can show you; this is at the very fundamentals of PLC programming. There are some good online training sources too.
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
774
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
587
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
654
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,144
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,266
