Configuring MicroLogix in CCW for HMI
zblum
Mar 2016
Ohio
38
Hey guys, I am trying to configure a PanelView 800 to communicate with a MicroLogix 1200 using DF1 serial protocol. I am very confused by CCW's menu and communications configuration page. I am able to download my application to the PanelView, but it gives me read and write errors (I am addressing tags by just using their PLC address, e.g. B3:3/15, and am referencing them to the controller I set up in CCW).
I am sure that this is because I have something configured incorrectly. I am using an R-model MicroLogix, so I have two comm ports on the PLC. I am able to communicate with the PLC fine, but is there a setting I'm missing? Any help would be appreciated.
did you try connecting it through ethernet via NET ENI? is your tagging correct like {::[PLC]B4:3/15} with PLC defined in the communication topic under rs enterprise?
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
787
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
595
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
665
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,175
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,278
