Connecting SLC 5/05 to DH+
The Plc Kid
Feb 2009
Macon, Georgia
3,233
Guys
What is the best way to connect a SLC 5/05 to a DH+ network?
What is the best way to control some more 1746 I/O via RIO from this SLC 5/05? Can it be done?
Anyone ever used this http://mediaii.com/OLDI_Updates_7_09/pdfs/ON0640_SLC_1.pdf
I have the rio I/O part covered now i just need to get this 5/05 processor on the dh+ network for program access and data collection.
I've never seen that device, but your last sentence above sounds a bit backward.
Wouldn't you want to get your DH+ device(s) on ethernet for data gathering? I guess that depends on the machine that's doing the collection.
I would go with the Controllogix gateway (since you want the best method). That's the best way I'm familiar with.
There is a data collection pc that runs some custom data colletion software that we had made some years ago. The pc has a DH+ ISA card in it.
There are 12 plc's on this DH+ network and we had to replace the GV 3000 reliance drives that were on dnet and add a new pv + so we put the 5/05 in to hadle the PV + and we put 755 drives in on dnet. There is a seperate ethernet based data collection system for this one machine that also uses the 5/05.
Now they come up and want to reconnect it back to the old system in addition to having the new system. I was looking for maybe a module that is 1746 based and could go in the chasis and give me a DH+ connection so i could connect back to the old system also.
I could do a clx chasis and make a gateway which would be DH+ reading ethernet messages and it normally is done the other way around. I am not sure it will work? has anyone ever done this? There is no room in the control cabinet for a clx gate way so that would mean adding a seperate enclosure which we can do but i would prefer not to if there is another method?
Could you change the processor back to a 5/04 and use a NET-ENI to connect to the PV+? Would allow you to use the old data collection system, and if you place a CLX gateway anywhere on the DH+ network, that would allow ethernet connectivity to it.
The old proprietary data collection system cannot be updated to work over ethernet ?
If the old data collection system isnt possible to maintain, I interpret it as a dead end that you will have to navigate out of sooner or later. Better sooner than later.
What some ways to connect an Ethernet only PanelView Plus to a SLC 5/04 without upgrading it to a SLC 5/05?
5,021
Hi there, I am doing a site survey for an older plant which my company has started working with. There are mutliple different PLC's around the...
4,476
I have a SLC504 in the field that is communicating DH+ to several other SLC504 and the RS232 port is communicating to a panel view plus 1000. I...
1,285
Hello, I'm a electrician who is furthering my education and learning to be a programer , I have a Dell laptop running windows 7 with rs logics pro...
22
6,353
Hello everyone, I have a question about connecting to an S500 PLC. I have been tasked with going to site and taking a backup of a program from an...
3,899
