connecting to slc 5/02
mdeltat
May 2007
Los Angeles, Ca
84
Can i connect to an SLC 5/02 using a standard ethernet cable? The only other cable i have is the one that i use to connect to slc 5/04 through my pcmk pc card.
No
A 5/02 uses either DF1 (Serial) or DH485.
DO NOT TRY TO USE ETHERNET -- YOU'LL BURN SOMETHING UP!!
SLC-5/02 is Data Highway-485 ONLY
That RJ-45 modular connector on the SLC-5/02 controller is for A-B's Data Highway 485 network only.
DO NOT plug an Ethernet cable into it.
Connection alternatives include the old 1747-PIC interface to RS232, the new 1747-UIC interface to USB, or a 1784-PCM4 cable for your 1784-PCMK card (get Series A or Series B cable to match your card).
What some ways to connect an Ethernet only PanelView Plus to a SLC 5/04 without upgrading it to a SLC 5/05?
5,010
Hi there, I am doing a site survey for an older plant which my company has started working with. There are mutliple different PLC's around the...
4,471
I have a SLC504 in the field that is communicating DH+ to several other SLC504 and the RS232 port is communicating to a panel view plus 1000. I...
1,277
Hello, I'm a electrician who is furthering my education and learning to be a programer , I have a Dell laptop running windows 7 with rs logics pro...
22
6,317
Hello everyone, I have a question about connecting to an S500 PLC. I have been tasked with going to site and taking a backup of a program from an...
3,887
