Control Logix 1756-L55 Serial Port Fault
bob1371
Mar 2003
Southern Indiana
355
Hello,
I have a Mitsubishi GOT HMI connected to this processor via serial port. A few times a week it will freeze up and may take several minutes and/or cycling power to reset. I have swapped HMI's with another line and it still happened. Swapped PLC's and the problem followed this particular processor.
I am thinking serial port going bad. When I look at Minor Faults tab I have the following.
(TYPE 09) SERIAL PORT FAULT
DF1 SLAVE POLL TIMEOUT (CODE 05)
I do have a ethernet card installed and wondering if I could use something like this.
http://www.moxa.com/product/MGate_EIP3000_Series.htm
Looking through the manual I need to see if I am communication with PCCC commands, if so it should work. This is where i'm lost now. Not sure how to check that or to verify if it will work or not.
I have priced a replacement PLC and will do that if needed but just looking for alternatives.
Thanks,
I have am trying to determine if I can use a 1756-IB16I (or some dc input equivalent) to handle a 24vdc input pulse frequency of 80 pulses per...
931
Folks, Putting together a system utilizing a Control Logix Gen 8 (5580) PLC w/ the L83e CPU. I'll be connecting to 8 different FLEX-IO drops...
4,092
Good morning. This is something new to me. we have an existing controller running one of our plants. we are doing a conversion on another...
1,249
As the title suggests, I'm pretty new to control logix. Well, what I am supposed to do is connect like 8-2 wire analog sensors to this card. From...
1,651
Good Morning , We had to change out a L61 with a L71 processor and it seems like our motion control is not the same . Have any of you run...
1,844
