We have recently experienced two failures on our Allen Bradley Controllogix PLCs and I have been tasked with researching the problem and hopefully finding a solution. One of the PLCs is a 1756-L55 Controllogix Controller Rev 13.25 & the other is 1756-L55 Controllogix Controller Rev 11.25
On both occasions the PLCs have been online with our programming Laptop, and on both occasions the laptop has frozen while we have been looking through the Logic then the system has tripped.
On each occasion we have had no PLC fault lights illuminated and when we removed the laptop the faults have not reoccurred.
On each occasion there has been a background communications program called Notifier Gateway running. Is it possible that this may have interfered with the communications between the Laptop and the PLC causing the problem ? We have since been on line with our laptop with all background communications programs shutdown and not experienced the fault again.
Are there any hotfixes or updates we need to prevent this from happening again?
