Couple of RSL5000 questions
ceilingwalker
Mar 2010
Phoenix, AZ
1,587
Hello. I have a couple of very basic questions about RSL5000. I went through training many years ago but haven't used it much since. First, the project I am working with has mainly FBD. When I am online with a CLX and looking at the function blocks of a Boolean value, I see a "0" and sometimes a "1". I assumed it was showing me in run time (more or less) what the condition of the input or output is. I ask because I have a door switch that I change the condition on and that number does not change, on the RSL5000. Of course it could be the switch is bad but I am thinking more that it isn't displaying that run time data.
Second, why is it that some Input devices or tags have a dot in the end of them and others don't? I am not talking about the dot to indicate an inverter, I am talking about the tiny dot in the end. This isn't limited to the inputs, outputs have them as well. Final question, is there a way to take an FBD and convert it to ladder logic, to read it? Thank you.
So the 0/1 should be updating to show you the status of the switch. I would check and verify you have the correct tag and then check the status of the switch.
The dot you see indicates Boolean. A pin with a dot is expecting or outputting a a true/false signal. A pin without is expecting/outputting a value.
OG
I am having an issue getting a IY4 to read my thermocouple correctly. We have a R type and K type hooked up and sitting at a known room...
555
Posted by u/mr_biodtox 44 minutes ago Delta ISPSoft - Establishing communication with thermocouple module Hi, How do I establish communication...
345
Hi, We have an ongoing project with a lot of thermocouple involved that monitor the temperature of heaters. There are more than 20 PID...
32
3,508
Hello. PLC beginner here, so apologies in advance for any incorrect terminology or poor communication. I have an SLC 500 Thermocouple/mV Analog...
655
Hello Guys, Trying to scale a thermocouple directly into my IY4 card. Connected into the terminal +\-. I’ve scaled the range of my J type to...
1,692
