CP340 Comm problem with printer
EECS_Guy
Feb 2009
TEXAS
I've got a CP340 RS232C that sends print commands to a Domino inkjet printer. My problem is that it will work without issue for weeks/months and then quit working altogether. I change to a manual way of printing labels for a few days and then go back to trying the ink-jet printer (and the P_SEND) and it has always started working again, without explanation. Well, this time is has not come back.
I've investigated the P_SEND call when it's not printing and the P_SEND is not setting the "done" or the "error" bits. The P_SEND is getting called properly every time a print is needed but no done bit. It's quite strange. When neither bit is set, the remaining logic "hangs up". I updated the P_SEND block from v1.1 to v2.0 (per Siemens' recommendation), but it has not fixed it. Does anyone have any ideas?o_O
I have a siemens CP340 communicating with Prosoft ADM module and if sometimes by anycause if the PLC goes to stop mode and comes back RUN mode...
1,472
Dear All, Can you please give me some steps to communicate between S5 CP524 and S7 CP CP340 with 3964R procedure. I have tested 3964R...
1,808
Hallo, I have Tia Portal V16 and I'm upgrading an older machine. That machine has a component running on rs232. The machine has still the old...
965
Hi all, i have a module from b&r automation and i am want to get the data from it, but the com port is already taken. Is it possible to monitor...
1,162
Hi, I am planning to use the 300 series in redundacy by using two cpus, and IM153 modules in Profibus DP. I am having some problems with my...
1,196
