CX Simulator Problems
rseles
Jun 2007
Brampton
I have CX Simulator as part of the CXOne package and I have noticed a peculiar problem. My PLC is a CJ1M-CPU13, set for Toolbus, COM3, 9600 baud, FIN Address-Network=0, Node=0. Every time I launch the simulator, it starts the simulator menu, and then asks:
"Modem port has been selected. Do you wish to continue?". When answered yes, and communication error "Failed to connect to PLC" crops up. I have tried several different communication settings, but with the same result. I have this installed on my Dell Inspiron 9400 laptop. Interesting thing though, when installed on a desktop, with the same settings, it seems to work fine.
Any suggestions??
These are the versions of CX Programmer exe and dlls:
C:\Program Files\OMRON\CX-One\CX-Programmer\CX-P.EXE 6.1.1.5
C:\Program Files\OMRON\CX-One\CX-Programmer\CX-PRES.DLL 6.1.1.3
C:\Program Files\OMRON\CX-One\CX-Programmer\CX-PDATA.DLL 6.1.1.5
C:\Program Files\OMRON\CX-One\CX-Programmer\CX-PDRES.DLL 6.1.1.5
C:\Program Files\OMRON\CX-One\CX-Programmer\SYSWIN.DAT 10/21/04
C:\Program Files\OMRON\CX-One\CX-Programmer\FILEPORT.EXE 5.0.0.0
C:\Program Files\OMRON\CX-One\CX-Programmer\FPORTRES.DLL 5.0.0.0
C:\Program Files\OMRON\CX-One\CX-Programmer\SWP_CXP.OCX 6.0.0.0
C:\Program Files\OMRON\CX-One\CX-Programmer\SWPCXRES.DLL 6.0.0.0
C:\Program Files\OMRON\CX-One\CX-Programmer\CCXPIMPORTEROCX.OCX 5.0.0.0
C:\Program Files\OMRON\CX-One\CX-Programmer\OCXPRT.OCX 6.1.0.2
C:\Program Files\OMRON\CX-One\CX-Programmer\OCXPRTRES.DLL 6.1.0.2
C:\Program Files\OMRON\CX-One\CX-Programmer\KBASECOMP.DLL 6.1.1.5
C:\Program Files\OMRON\CX-One\CX-Programmer\KBASECOMPRES.DLL 6.1.1.5
C:\Program Files\OMRON\CX-One\CX-Programmer\LADDERDOCUMENT.DLL 6.1.1.2
C:\Program Files\OMRON\CX-One\CX-Programmer\LADDERDOCUMENTRES.DLL 6.1.1.2
C:\Program Files\OMRON\CX-One\CX-Programmer\LADDERPARSER.DLL 6.1.1.0
C:\Program Files\OMRON\CX-One\CX-Programmer\LADDERVIEW.DLL 6.1.1.0
C:\Program Files\OMRON\CX-One\CX-Programmer\LADDERVIEWRES.DLL 6.1.1.0
C:\Program Files\OMRON\CX-One\CX-Programmer\PHEADDOC.DLL 6.1.1.1
C:\Program Files\OMRON\CX-One\CX-Programmer\PHEADDOCRES.DLL 6.1.1.1
C:\Program Files\OMRON\CX-One\CX-Programmer\PHEADVIEW.DLL 6.1.1.0
C:\Program Files\OMRON\CX-One\CX-Programmer\PHEADVIEWRES.DLL 6.1.1.0
C:\Program Files\OMRON\CX-One\CX-Programmer\STEDITOR.DLL 6.1.1.0
C:\Program Files\OMRON\CX-One\CX-Programmer\STEDITORRES.DLL 6.1.1.0
C:\Program Files\OMRON\CX-One\CX-Programmer\STRUCTUREDTEXTCOMPILER.DLL 6.1.1.1
C:\Program Files\OMRON\CX-One\CX-Programmer\STRUCTUREDTEXTCOMPILERRES.DLL 6.1.1.1
C:\Program Files\OMRON\CX-One\CX-Programmer\POUTYPECONTAINER.DLL 6.1.1.0
C:\Program Files\OMRON\CX-One\CX-Programmer\POUTYPEMANAGERCONTAINER.DLL 6.1.1.0
C:\Program Files\OMRON\CX-One\CX-Programmer\STRUCTUREDTEXTDOCUMENT.DLL 6.1.1.0
CX Simulator version is 1.6.
I don't show a COM3 under device manager (LPT/COM ports), but the on-board modem is configured to access COM3. When I change the PLC type under CX Programmer using ToolBus, the port always defaults to COM3, with no other selection available on the drop down list.
Ah!!!! Dell and Windblows again.
I have had a similar problem with a HP laptop in the past. Disable the modem.
Have disabled the modem, but in doing so, this deletes the only COM port (COM3) that can be selected from the pulldown list (using Toolbus driver). When adding another serial port in WinXP SP2, the serial drivers have problems loading.
I would be leaving the modem disabled for now and removing and re-installing CX-One. This is a pain as the removal does not work very well. I find I had to uninstall every program one at a time, delete the directory and then use Registery Mechanic to clean out the registery before re-installing CX-One.
I downloaded and installed the Connection Components Workbench Standard and have followed your video to the point where I setup the connection...
2,696
Phil, I was trying to write a program on the simulator. I ran into a problem where the tags for the contacts and coils disappeared. I also...
1,469
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
74
Showing a new guy basic programming and remembered the simulator here. But nothing happens when selecting the link. "Try our online PLC Simulator-...
25
1,645
My PLC (S7-1200) and HMI (KTP-1200 Basic) has been delivered on-site to the customer. To be able to do "off-line" updates to the code, I am using...
226
