Cylinder Tank Cubic Meter calculation
zai_jnr
May 2008
MALAYSIA
169
Dear All,
I'm now working with CPU PLC Mitsubishi QO2U CPU. There have cylinder tank system that fill up with fuel from outside to inside cylinder tank. I've got assignment to display current volume of tank to human machine interface. To check level of fuel inside tank, I'm using Hart Level Transmitter (4~20mA).
Got problem to do programming ( find formula) to calculate current volume of petrol inside tank. If the tank installation to lay on the ground in vertical position, I think not big issue to calculate cubic meter of medium inside tank.
The problem is the tank in horizontal position.Any idea how to calculate current volume inside tank when tank in horizontal position?
High Tank : 300 meter
Diameter Tank : 30 meter
Cubic meter Tank: n(j)^2H = 3.142*15*15*300 = 212085 cubic meter
You get what I mean in this post?
The formula for volume of a liquid in a partially filled horizontal cylindrical tank with flat ends is
r = radius of the tank.
l = length of the tank.
h = height of liquid in the tank.
volume = l * (pi*r^2/2 - r^2*arcsin(1-h/r) - (r-h)*sqrt(h(2r-h)))
The formula computes the chord area of the circular cross section of the fluid at height h and then multiplies the cross section area by the tank length.
However, horizontal cylindrical tanks usually don't have flat ends, and they usually aren't exactly round, so simply using a formula can have significant discrepancies from the true amount of product in the tank. When high accuracy is needed it is more common to use a look up table that is customized to the particular tank.
There have been many discussions about measuring fluids in horizontal tanks on the forum. Do a forum search to see some of the threads where common problems and solutions are discussed.
Hi All, It probably has been discussed before....but... My PLC is a AB L71 Processor (RSLogix5000 v20) I have a Horizontal Round Cylinder Tank...
27
11,273
I'm trying to find the formula for the inflow rate or outflow rate of a cylinder tank knowing the Volume. Looked online and did not find much...
5,278
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
241
Hi Friends, I am facing a problem with encoder adjustment in Sew Electric Cylinder CMS71L. encoder using is Sick Hiperface Drive is MOVIDRIVE...
17
808
It's very embarrassing but when I can't come up with an answer fast, I do need all the help I can get. I have rotating cylinder. One output...
1,600
