DeviceNet Autoscan
bone
Dec 2004
Amish Country - PA
58
I'm upgrading my projects to utilize the autoscan feature in the 1756-DNB (firmware 5.0+). It works great - no more hassle of using RSNetworx to build scanlists. Is there a way to 'drop' a device from the scanlist if the node (encoder) is removed? When I test this, the node that was automatically added to the scanlist showed up, but when it was removed, the corresponding bit in the DeviceFailureRegister register goes high. Is there a way to bypass this, and just have the scanner re-read the scanlist. (Either automatically, or via HMI)?
Thanks,
bone
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
106
We've run into an old system that we are upgrading which is still running Steeplechase with Citect using Devicenet to Wago. I had some experience...
149
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
133
Good day Forum Members I got a older Lincoln welder and hoping to make it work at our shop. Welder in question is the Lincoln Power Wave 455M...
209
Hello Friends We have 10 Powerfocus 4000 with DeviceNet, We need to backup the configuration, the Powerfocus is detected but as unrecognized...
110
