DeviceNet Autoscan
bone
Dec 2004
Amish Country - PA
58
I'm upgrading my projects to utilize the autoscan feature in the 1756-DNB (firmware 5.0+). It works great - no more hassle of using RSNetworx to build scanlists. Is there a way to 'drop' a device from the scanlist if the node (encoder) is removed? When I test this, the node that was automatically added to the scanlist showed up, but when it was removed, the corresponding bit in the DeviceFailureRegister register goes high. Is there a way to bypass this, and just have the scanner re-read the scanlist. (Either automatically, or via HMI)?
Thanks,
bone
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
81
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
190
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
150
We've run into an old system that we are upgrading which is still running Steeplechase with Citect using Devicenet to Wago. I had some experience...
168
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
158
