Devicenet/Controlnet RPI and NUT
smiller
Aug 2003
Arizona/Brazil
116
I have a Devicenet network that has about 12 Toshiba VFDs that intermittently drops out and the operators are able to immediately re-start the affected pumps and keep the plant running. For this reason I am not able to see if there is an error code on the DNet module when it happens. It sometimes can go weeks without a problem.
The system is a Controllogix L74, Controlnet to a secondary rack that contains the Dnet scanner. I have a NUT of 4ms on Controlnet and RPI of 40 on the Dnet scanner. I see a lot of network update overload errors on the Controlnet. Can anyone tell me how to set up the RPI/NUT and if that is even the cause of the update errors?
Thanks.
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
2,312
We have a few systems that use DNet and CNet. I noticed there were programs called RSNetWorx which after checking out I see is a topology tool...
3,816
Gents, I have a problem when I want to use the device bridge 1788-CN2DN (controlnet to devicenet). I just wanted to know if someone in here had...
2,655
1,488
Hi everyone, I am on a quest for knowledge.📚 Over the years I have become very familiar with RS-232, 485 and Ethernet but have had no...
3,169
