industectron
OP
Ahh Matt, another good point that I've been tossing around. Since I'm new to DN I was wondering about hardware. I don't have a grasp on what the pro's and con's of the different ways to connect these guys. The one thing I saw that might make life better is the connectors. We have, what I quess is the standard, 5 chamber screw type. Getting both wires in one hole is cumbersome. I was thinking that the 10 chamber screw type would make it alot easier for the guys daisy chaining these devices. have you seen them used?
I am going to check out those "T"'s you mentioned. I can see those could help reduce drop length and could be a solution where the thick cable is in a small area and bend radius is an issue.
