DH485 Network for SLC5/03
sherman4
Jun 2002
46
Hello
I would like to network some distributed SLC5/03 processors using only DH485. I was wondering if I can use 1747 NET-AIC interfaces at every SLC to link them to the single DH485 trunk, instead of using 1747-AIC couplers. Is it still a good idea?, I just want to keep them isolated for the DH-485.
DH+ and Ethernet are not options for my application.
If anyone can advice or has had previous experience with NET-AIC for isolation, thanks for any advice !!
Thanks again.
Did you mean 1761-NET-AIC's instead of 1746-NET-AIC's?
We use the exact network structure in our plant. We've got 5 or 6 SLC 5/03's each with an RS232 cable going to the AIC+ (1761-NET-AIC) which gives them all connectivity to the main-network, while they all maintain an internal DH-485 network using the other communications port.
The main-trunk as you described it, does get pretty slow though.
Hope this helps,
-Dave
I have an allen Bradley system in which there is two micrologix 1200 and two panel view 300 and a Rsview 32 connected on DH485 network with the...
1,778
Hi, i am trying to create an DH485 netwrok which will consist of 2 ML1500 using ACi units for data acquisition back to a pc. i understand how...
2,010
Hello All, I am currently troubleshooting a communications issue regarding a DH485 network. The network contains PLC1, PLC2, and PLC3, all AB...
3,808
So I am attending a site next week that is reporting PLC communication issues between its three SLC 5/03s (PLC1, PLC2, PLC3). PLC2 communicates...
1,805
Hi, I want to know if and how i can bring up my DH485 network to a ethernet/ip. My network is setting with 1747-aic and 1761-net-aic. So i...
2,305
