Don't want an "S" curve..need a cosine curve
Hi uncle Lamboom,
how you adjust the frequency in cosine mode?
It's in the SIN equation: Sine_Time/Period, where Sine_Time is from the ModReal expression (It's an Omron Sysmac Studio thing.) This info came from an Omron Engineer, Tyler Corbett, in Canada. (where all the friendly people live.. :)
SampleTimeSec:= TO_LREAL(TimeToNanoSec(GetMyTaskInterval())) * 1e-9; //in this case it equals 0.001 sec .. it's sensitive to whatever the task interval is in the Omron NJ
Sine_Time:= ModReal(Sine_Time + SampleTimeSec, Period
Position := Amplitude * SIN((2 * Pi * Sine_Time / Period) + (Pi * 1.5) + Amplitude
Attn DIRT: Back to that Tsunami equation.... I Changed to using State Trackers (like your Stages) .. That worked well .. No clunks, and the sequence runs fine; but, only up to a point. There is a point at short periods (0.3 sec) to the positive peak of the cosine ramp up, when the control fails and the linear motor runs away negatively into the hard stop. (have nice shock pads for that..)
This may be due to the position equation itself. By creating only 180 degrees of motion mathematically ( SIN(2 * Pi * Time increments/Period) + 270 degree Offset) The 2 is not in this equation) The equation is only for a half cycle... perhaps it should be in the equation... or something a little larger than 1 . Because, the "end" timing is too critical. In only one CPU cycle, (0.001sec) the curve will go from + peak(max) to zero!. Probably, better to make the cycle go slightly past + Peak(max), but try to catch the + Peak(max) with the IF-THEN statement.
Edit ... Just tested it .. Yup... gotta use a position equation that passes the peak a little... I now can do a "impact' simulation of a stroke of 100mm in 0.1 sec .. or faster.. LinMot is awesome!
Hi Peter .. always nice to hear from you. Ya know, after trying to get an Omron NJ to do non-typical machine automation moves, I have come to appreciate the incredible work your design team created in the Delta programming software. Sure, I was a newbie, but it was so intuitive, and simple to create everything I could imagine from curve shapes determined by complex mathematics, and ramping any variable .. all, on the fly, in real time. Damn near everything you need to do with Omron NJ is by brute force. Well, that's not entirely fair ... they do have a few bells and whistles... an' their NA HMI is cool (not as good as Red Lion .. but OK.)
These are very slow test moves. When moving water, the LinMot needs harder PID tuning .. I see forces up to 135 pounds.. with some moves in the 0.4 Hz range.. I can't use hydraulics, leaks are inevitable, an' water and oil don't do well together. You have any really cool projects lately, other than helping land the Curiosity rover on Mars? Also, did you know Delta played a role in the last King Kong movie?
It looks like you did it!
I didn't know that. I usually don't get too involved in tech support unless all our tech support guys are busy or the problem is difficult.
Movies are great for publicity but there are a few people that do most of hydraulic controls. They bought a RMC for movie making but they buy only one for all future projects/movies. Earlier this year I talked to the guy that did the hydraulic controls for Transformers 1,2 and 3. For some reason he didn't do 4 but is going to do 5. He bought only one controller and will use it for all his movie projects. I get more excited when a OEM standardizes on our products because that is recurring sales and usually after the first few systems they are cookie cutters so support is low.
I have been reading everything I can find on the P_LLS the last 2 days but I am still having trouble understanding how the P_LLS swaps beyond 2...
583
In OB1, I'm monitoring some values (first pic). The values are what I expect. At the same time, I'm monitoring the same values in the DB where...
652
Maybe I am the last to know but Rockwell has put an EOL date on the 3 motion modules at the end of 2024 but maybe sooner. I know this will affect...
964
On the laser displacement sensor now connected to my PLC, the manual says 4mA=643 and 20mA=64,877. However, I checked with a Fluke, injecting...
892
I'm from a Mitsubishi Q-series background so excuse my ignorance. In Mitsubishi world, in my experience your Mbits (booleans) are just M1, M2...
20
2,797
