Dp pressure logic
RY_Guthrie
Nov 2011
Las vegas, NV
263
I am installing a dp transmitter along with a temp probe and a static pressure transmitter and I am trying to figure out the best way to calculate the flow rate of a gas in a control logic using ladder programming. I was wondering if anyone knows of a place where i can look at examples of that logic? Does rockwell offer examples of it different logic? thanks!
ASME PTC 19.5 is the most authoritative guide to flow measurement. The equation relating differential pressure to flow will vary based on the primary element - pitot tube, orifice, flow tube, etc.
Has to be implemented on CX Programmer Under PAHH conditions the logic solver closes the S-ESD inlet valve and keeps the S-ESD outlet valve open...
2,436
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
269
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
139
I need to protect some pressure transmitters from hot (120°C) oil. Does anyone have a favorite transmitter cooling element/standoff they use...
172
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,918
