E-Signatures in PlantPAx
tbwebb2
Nov 2016
Raleigh, NC
Hello,
I have a client that is requesting E-Signatures within a PlantPAx HMI. I know this is possible with some custom VBA behind the PlantPAx faceplates. However I would prefer a cleaner, out of the box approach if one exists. Does anyone have experience doing this and what solution did you use?
Thanks!
http://literature.rockwellautomation.com/idc/groups/literature/documents/rm/proces-rm008_-en-p.pdf
The optional FactoryTalk eProcedure component displays operator instructions in a web page or browser ActiveX. eProcedure supports electronic signatures and signoffs captured in the batch journal.
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/batch-um011_-en-p.pdf
Please see "How electronic signatures work" in the above manual.
I have not done this but it appears to be an out of the box approach.
Hope this helps you out.
Regards,
You didn't mention what platform you'd be using.
FTViewME supports electronic signatures starting with 8.2. Couple checkboxes to enable.
Hello, If you sign off a safety signature for a machine, can it be used and valid on other processors if the setup is the same? Thanks
1,571
Hello, i need to use P_Intlk and feed the Status interlock OK bit to a P_DOut block. However, there's 17 interlocks for this output. How can I...
123
Hello All We have 3rd party vendors that run on older versions of PLC (Plc2.0) while we run the main system using plantpax and PLC 3.5-10. Plantpx...
104
Dear Members, Hello, we are working on a project and facing an issue with the plantpax 5 PMTR library, we have a bidirectional motor, which has 2...
255
The PMTR has a timeout parameter for run feedback during a start, but once the motor has been running for a while and loses that run feedback (to...
229
