shaheed
referance to this discussion bellow, I have also faced same problem. in my situation I have to be ensure 60 packet inside a carton ater gluing, i.e. in FG it need to be confirmed that there is no shortage. If anyone have the answer please help me.
eagerly waiting for a solution.
I have to mention you that, our total packaging sytem is fully manual and shortage inside FG due to neglency of our worker. I have tried to use weighing system but can,t because weight range is too high that cover a weight of a packet.
thanks
sinanissa
July 31st, 2007, 10:37 AM
I am asking this question because i think that someone may encountered this situation.
i am searching for a sensor that can detect the abscence of a box inside a carton. the carton contains 50 boxes, 25 in each side.
and the 25 are arranged in 5 by 5. if there is a sensor that can detect emptyness so i can tell that the carton is fully packaged or not thus i will be sure 100% that our production line gives excellent quality.
i did not use weighting system because i need online check that will not glued the carton, so it will go out opened.
thank you all for your help.
thanks
sinanissa
