Encoder
creativepaper
Feb 2008
Worcester
168
Does anyone know of a cheapish encoder (under $100).
ppr = 1 (can handle more but don't need more)
single or double - can use single, but would need to have 2 of them to determine direction
Voltage = up to 24V DC
Hollow bore with bore of 9/16 (I can be flexible with this)
waterproof - needs to be able to withstand a washdown and humid enviroment.
The location is not a high traffic area, so plastic would be ok.
Its used to measure the number of turns for a slice positioner on our papermachine. Usual number of turns per visit is in the 20 range so 1 ppr will be adequate.
It will be hooked up to a digital input card on our ControlLogix system (2 channels per encoder so I can determine direction).
Cheers for all the help
We would make our own.
If all you need is one pulse per rev, we usually use an inductor to read a slot in a disk.
Our current line of thinking is 2 magnets on a shaft with corresponding pickups to act as 2 single channels but we would prefer something that we can just bolt on instead of create.
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
255
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
341
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,060
Dears, i am trying to change the series of encoder from A to B, but the program do not has this option (Rslogix5000, 20.06 the old encoder was...
219
Hi all, I am working with an incremental encoder (ABZ signals, 360 ppr (so 1440 counts per rev)) to replace the existing "manual" encoder wheel I...
51
2,678
