ET200M backplane bus cover
huynt
Nov 2004
106
Dear all.
I want to use ET200M with active backpane bus. I read in ET200M manual, it have backplane bus cover, but I dont know, what is backplane bus cover, When I use it.
Thanks.
If memory serves me correctly.. The ET200M is a 'rack' with an IM153 and slots for up to 8 I/O modules, the same modules used with S7300's, so I think Jespers guess is spot on, if you only fit 4 modules in the rack then you will need 4 bus covers, to cover up the other 4 slots..
Now that makes sense
Paul
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi, A customer is requiring a ET200M in our control panel, I have never used them and would appreciate some help regarding if I understand it...
807
Hello friends I am about to get crazy, I am trying to connect a ET200M (Siemens) to a Prosoft card, the part number is MVI56-PDPMV1 in a...
5,114
Dear Experts, I have a question regarding the redundant S7-1500 CPU and ET200M connection. Will ET200M IOs work on a redundant S7-1500...
2,106
Hello, With regards to the bases of the ET200M and ET200 SP HA is there an appreciable difference in the physical footprint of the bases? From...
2,418
