Extending SLC racks
DairyBoy
Jun 2007
UK
393
Are the extension ports on an SLC rack dedicated to "in" and "out" function or can I connect an extension from the psu end of the rack to the same end on the extension? Thanks, db.
Mickey, my Adobe Reader 8.1 hangs trying to open the file, not sure if it is me or the pdf....
Just in case:
Important Installation Notes
1. Install the rack interconnect cable before installing the power supply in
multiple rack configurations.
2. The cables are “keyed” for proper installation. The end of the cable that
plugs into the left socket has the “key” on the outside of the connector. The
opposite end of the cable has the “key” on the inside of the connector.
Figure 1 displays the connector and the keys.
3. Make sure the cable is properly secured to prevent against the effects of
shock and vibration. To remove the cable, move the tabs on the socket
outward and the connector will pop out. See Figure 1 on the next page.
Refer to the​
SLC 500™ Modular Hardware Style Installation and
Operation Manual​
, publication 1747-6.2, for complete information.
4. The expansion cable must always exit the right end of the rack with the
CPU. Figure 2 displays correct and incorrect installations.
5. The 1746-C16 cable should be used when connecting two 1746-A13 racks
(one above the other) with 1746-P4 power supplies.
I used "CutePDF" to create it.
I use "Foxit" to read PDF files.
It worked for me when I read it back.
hi, I currently have a conveyor system with a S7-300 with Profibus, one 32DI Slave and 12 Danfoss 2800 VLT profibus also. all connected in the...
2,013
Hello, I've created a Global Object, and assigned it three Global Variable Parameters using (Context Menu -> Global Variable Parameter...
9,375
guys, I have a siemens s7-200 plc with ethernet communications. The problem is: We have to control this plc from 1500 feet away...
9,145
Hi all, In my next project the SCADA PC will be 10M from the control station where the Keyboard, Mouse and Monitor will sit. I have a couple of...
2,895
I would like to know the method to extend 14 day Trial License for Step 7. I tried with uninstalling and installing but it doesn't worked out.
50
13,426
