Extracting tags from Monitor Tag tab
godfrey
Apr 2002
Charlotte, NC
412
I want to export the controller Tags from the Monitor Tag tab in RSLogix 5000, ver 13. If I export, I get everything except the Values. What I need are the values along with the other information.
Typically, "live" data from your PLC is transfered through RS Linx software. Can you explain a bit more about where you want the data to end up? In a VB program, in a CSV file, SQL, etc? Then I'm sure more folks will be able to help with practical examples.
I don't need live data. I just need the data in the value column which is displayed in the Monitor tab. If I export the tags to a CSV file, I get everything except the value column. How can I get this column into a spreadsheet?
Not sure this is exactly what you want, but if you click the upper left hand corner of the tag monitor window (select all), and hit CTRL+C (copy), then paste into excel, the values will be copied and pasted. Basically, you'll get everything you see in the tag monitor window.
So, if there are tags that need to be expanded to show the sub-elements, go through and expand them all before you copy.
Hope this helps.
Paul
I am attempting to access HMI tag properties (Description, Minimum, Maximum values) to populate a numeric input. Is there a clean way to do this...
377
Hi all, I have a customer with an FTView SE system running some datalog files. They can see the trends on the client, but they now want to...
2,713
Hi, I'm using the 2080-MOT-HSC High Speed Counter plug-in module with a Micro850 (2080-LC50-24QWB) using the HSCE instruction. The encoder is a...
1,666
Hi, I am having trouble getting the .dmk file extracted so that ControFlash will see the new firmware revision. I hit extract all files and it...
4,790
Hello, I currently have a factory talk project (Project 1) that uses visual basic to calculate an integer. I am in the process of developing a new...
1,327
