Factory Talk View ME turn text.
haldunkle
Sep 2022
Pittsfield Pa
Hi everyone. I am in need of help on turning text in Factory Talk View ME. I know this has been asked before and I found the old thread/post. I tried following them with installing Stephen Lebans' Rotate Label ActiveX Control(v2.0). I used AccessRotateVer2.zip off of his web page. I manually registered both as per the older thread using command prompt. I can see it in the ActiveX list on Factory Talk and use it to create the labels how I want them but when I try to register it in Factory Talk, I get the message "Unble to Register Control". Then when I download my program to the HMI and go to the page using it, I get "Unable to load ActiveX Control for display" and a cause of "Access Rotate Text Control 2.0: ActiveX control not found on computer". My laptop is running Windows 10. Factory Talk View ME version 13.00.00(CPR9 SR13). I did find another forum that said to copy all files in the zip file and put them in SysWOW64 folder which I did. I am sure that I missed something simple but I can not figure it out. Any help would be greatly appreciated.
213
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
404
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
333
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
688
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
408
