FactoryTalk View ME Station Object Animation
vkolluru
Jun 2007
Maryland
I am developing a HMI using FTView ME Station (Formerly called RSViewME). I need to hide a push button until a certain tag value (from Contrologix) is greater than 0. I used the Visibility animation for this.
All seem to work except that when the button is invisible, a rectangular box (same size as the button) appears on the display.
Can anyone tell me how I can avoid this annoying rectangle.
Thanks.
Hi... I dont think the frame will be visible when you download your application to a "Panelview". It will only be visible, when you run your application on your computer
I was hoping this was the case at the back of my mind. My boss was still worried. The first thing I would be doing on Monday morning is load this on the PanelView Plus. Thanks Kolberg.
I have only messed with RSview32. I would check to see if the outline color is the same as the background color when the button is hidden.
Just a guess.
Ouch, thanks for throwing me under the bus,
Just kiddin
I want to try this with RSview32 at work tomorrow.
Thank you for the link.
Information from people like you make a huge impact.
Thanks again,
ph
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
85
Considering the incredible time it would take to get a Panelview Plus 7 , I'm going to get the FactoryTalk View ME Station 30 Display Single...
1,142
What is the main difference between the 2 licenses? I have a lot of experience with the Machine edition but not so much with the Server Edition...
4,135
Hello, I am looking to control 50 identical stations from an Allen Bradley HMI using FactoryTalk View Studio ME 11.00.00. The Stations are...
25
5,963
Heya Given lead times on a new PanelView Performance which we'd plan to deploy and connect to 2 x PLC's, we're in a bit of a pickle. Can we use...
1,187
