Fatek analog input help
ydtech
Jul 2008
Guaiba - RS
116
I'm saddled with a Fatek FBs-40MC with 2 FBs-6AD modules. If I understand the manual correctly the readings should automatically transfer to R3840 onwards. However, injecting a signal into Ch0 (R3840) the value is static. Is there some extra tricks I've missed? I have tried changing the jumper settings but that only alters the off-set (0 or 8192), nothing else.
Hey I am facing the same problem...I connected Fbs 6AD with my Plc and gave it 24V dc from the 24V output of the PLC...but i am getting the value 8191 from CH 0(R3840) and it is not changing...please help mee
I have given the FBs 6AD module and the sensor power externally ie 24V....but its still showing 8191 in the register R3840(CH 0)
Hello, I am working with FATEK PLCs... I have an AO module to drive 4 Inverters. I want to set Inverters from 0% to 100% of their speed...
1,771
i want to scale a 14 bit input (0-16383) to 0-3000 scaling ,but winproladder dsnt give a built in function i guess like...
4,840
Hi...I am connecting the Fatek analog module to the FBs 32Ma PLC ..But when i am retreiving data from the analog module it is always showing...
2,987
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
144
Hi everyone, i hope you are doing well i am using fbs 2lc module , i have calibrated the weight by calibrated weight but my value is not...
86
