FATEK Analog Output Function
manin
Jan 2015
Athens
37
Hello, I am working with FATEK PLCs...
I have an AO module to drive 4 Inverters.
I want to set Inverters from 0% to 100% of their speed...
Analog Output prices are 0-16383...
How can I scale these prices?
There is not any conversion function, like AI conversion...
I tried to do it mathematicaly, but I have problem with numbers after decimal point...
Any ideas?
OK...The solution is that the same function, for AI scaling is being used also for outputs...
Thanks !!!
i want to scale a 14 bit input (0-16383) to 0-3000 scaling ,but winproladder dsnt give a built in function i guess like...
4,841
Hi...I am connecting the Fatek analog module to the FBs 32Ma PLC ..But when i am retreiving data from the analog module it is always showing...
2,987
I'm saddled with a Fatek FBs-40MC with 2 FBs-6AD modules. If I understand the manual correctly the readings should automatically transfer to R3840...
2,988
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
144
Hi everyone, i hope you are doing well i am using fbs 2lc module , i have calibrated the weight by calibrated weight but my value is not...
86
