Figuring out what Festo valve bank part number means.
CapinWinky
Aug 2011
Virginia
566
When ordering a Festo CPX valve bank, they give you one big crazy part number, like:
50E-F14GCQSER-S+N
44PN-R-U-KX-AA-4M
I need to be able to back out of this what the parts are in the valve bank for reasons that are completely idiotic* on a regular basis and my go to is to ask our Festo rep. He's on vacation and I'm a little embarrassed to keep bothering the guy over something so trivial.
*The guy that specs out the valve bank is either autistic or an a-hole and will only direct me to a system I don't have access to so I can look it up. I do have access to the line item on the PO, so I've been bypassing the bum and going direct to Festo for my answers.
The CPX valve bank is configurable. The 50E xx is the electrical part with a fieldbus node and an input module. The 44xx is the valve part. It is rather small with four single coil 5/2 valves. There should be a six or seven digit numeric part number on the sheet you have. What is it?
+1 for configuration software or catalogue. The stuff is built to order, so the part numbers can become ridiculously long (Same as SEW gear).
Using the catalogue link I have deciphered the number for you.
Take a look at the pdf attachment see if it helps
Steve
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
776
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
588
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
658
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,148
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,269
