filter differential and the PLC
John Morris
Sep 2015
San Antonio
689
I suck at theoretical math.
I have a bank of six filters
Four to tank one (5 Hp pump motor)
One each for the next two tanks (3 Hp each)
I have pressure sensor (0-30 psi) on either side of each filter generating a 4-20 mA signal
Would the formula (f1 + f2) / 2 = filter differential pressure be accurate.
Thank you for your time and attention.
(YES I tried Wikipedia, gave me a head ache)
Any recommendations for a DIY home automation suppler that has a inexpensive WiFi device that I can use to monitor my HVAC filter. Thanks, Bob O.
3,332
Kindly, we have the following configuration fault on a Kinetix 5700 axis. It only appears when we go online on the Plc. We are just starting the...
97
When supplying variable frequency drives (vfd), should we install the line filter (emc) before the reactor (choke), or reactor before filter...
197
Hi. I'd like to have a filter on an Alarm Summary page where I could pick which of the 3 groups I created I want to display on the screen. I...
555
Good morning, I'm new to PLC and HMIs, and I was given the following problem: I need to be able to filter alarms and events that are only related...
391
