FT SE v11 Alarm and Event Historian events deletion.
npham
Aug 2015
Iowa
Hi everyone,
I'm currently working with FT SE v11 and using the 2014 SQL Server Express. I got the database to connect and logging events. The problem I'm having is trying to delete old alarms/events. For testing, I have configured the database size management options to delete events older than 3 days. I have been monitoring for about a week now, but no event gets deleted from the database. I followed the Rockwell website's FactoryTalk ALarms and Events System COnfiguration Guide. Not sure what I'm missing, and if anyone else experienced the same problem?
Please help!
Thanks.
One thing, I don't recall what permissions the user that inserts the events has, but that same user would need whatever permissions to delete old events as well and/or execute stored procedures. Might check that if you aren't using SA (and you really shouldn't be using SA...)
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
224
Hi all, I'm a bit of a noob with Siemens. (I know enough to be dangerous) I've come across a V11 offline program that doesn't match the online...
1,662
Hi, Rockwell level: Novice ; Siemens is more my gig. More formal training there. I own a license to FTV ME, the panel this runtime is located...
2,318
Hi, Yesterday I decided to try to download a program to device using my virtual machine which runs Windows 7 Professional and TIA PORTAL V11...
5,637
Has anyone had luck using a checkbox control (specifically Microsoft Forms 2.0 Checkbox) on a graphic? I assigned a tag to the "Value" property...
1,543
