FTV ME "programmed in version" help??
Yeah the 64/32 bit thing is definitely not reliable. It's something I tossed in last minute and clearly needs another approach. The main goal was to identify the targeted version which seems to work well. I'm going to see what I can do about the 64 bit thing when I get time. Glad you've found it useful.
I think the key to which architecture the project was created on lies in the PRODUCT_VERSION_INFORMATION. I looked at that file once before but I don't think I had any 64bit examples at the time. I'll post an update when I get a few...
Well there is something that can be done with the VERSION_INFORMATION file but it's quite the procedure. I'm trying to figure out a way to write software to automate the process but here's basically how it works:
Unzip a MER with 7zip.
Open a the VERSION_INFORMATION file with Notepad++
Use it's converter plugin to convert the text from ASCII -> HEX
This will reveal the following:
030720 = V7
03060A = V6.10
030620 = V6.0
0305 = V5.10
030520 = V5.0
030420 = V4
Didn't try < v4 but I'm sure that there's a pattern here...
If I can figure it out, my hope is to make a small executable that you can just point at a MER and have it do the above work for you to report the version. Or maybe there's an easier way, we'll see...
= v8 ???
030920 = v9 ???
030A20 = v10
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
134
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
106
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
140
Hi to all, Does TIA portal support creating reusable pop-up display as FTV has it implemented? Something like on link below. Thanks in advance.
537
Hi all, I have a question about the communication from the FTV and the PLC for different machine I use. Most of these use a SLC5/04 PLC and...
302
