fx-1s operator panel interface
muds
Apr 2014
karachi
71
hi all
i want to add operator interface to mutshibishi plc Fx1s-series,,
can any one guide which operator interface can directly communicate with mentioned PLC.
Thanks in advance,,
hi all
Thanks in advance,,
Do you need a touch screen one, one with buttons, text only, etc etc ?
Have you looked at the Misubishi GOT range ?
Most HMi's will have drivers to communicate with the FX1s
Beijers used to be partners with Mitsubishi and so their HMI's work well plus the cable is easy to buy.
i am looking at FX1N-5DM & FX-10DM-E,, to interface it with my FX1s PLC..
i just need operator input(time dealy) from that screen,, are that upto my task?
or any suggestion??
Mitshi GOT panels, Beijer E100 and E1000 and IX panels will work. Also new Siemens Comfort and Shneider Electric STU panels will do the job!
I'm looking for an Operator Interface panel that is capable of generating reports into a Secure PDF format to meet FDA requirements. Space is an...
2,227
Hello everyone, I had a operator touchscreen panel from Giddings & Lewis - PIC 2100 series and I am trying to connect it to the 485 port of an...
3,868
Hello everyone, we need to use android tablets that simulate Rockwell's panel views (tablets will be replaced by hmi which are having very long...
3,503
hi everyone im using OPERATOR PANEL SPOT PLUS 150 35W 24VDC AUTOMATA ID42003 (as hmi system) and automata optispark controller to control and...
2,413
Hi, I get an error message "version on your device is not compatible with WinCC Flexible" I know i have to update the OS, and i found a document...
34
8,431
