G120c DP Manual move button
Avatar_41
Aug 2019
Istanbul
96
Hello everyone, friends. I need to make changes to a project that I have done before. S7-300 I made a conveyor using a G120C DP driver for the machine used. While doing this, I used the Standard Telegram 1. PZD-2/2 Communication format together with the Profibus communication network. I was doing operations such as stop, start, speed adjustment of the conveyor via HMI. Now my problem is: The conveyor will be moved to a farther point. And reaching the hmi screen is a waste of time. I was asked to leave a Manual selector switch, a back and forth button and a speed adjustment pot. I struggled a bit, I chose Macro number 1 to run back and forth to try.
p1003 : 300
p1004 : 400
I entered the values.
+24V to DI0 (terminal 5). When I give it, there is no movement on the conveyor.
How can I solve this problem? Am I missing something with the wiring or have I entered a missing parameter? Can you please help me? Thanks in advance. Please see attachment.
  • expert list.pdf
  • parameter_Expert list_backup.zip
Why dont you wire the manual selector as a digital input to plc and still only control the drive via profibus?
agree with chud.
You have a PLC, and in the PLC program you generate the speed setpoint which you then send to the G120C via telegram 1.
Change the PLC program to set the speed setpoint based on the physical switch.
At some point in the set-up you need to send the PLC, so you might as well do it all in there.
You'll need to talk to the PLC because somewhere in your program you must be activating a bit (bit 10 in the default control word I think) which is labelled "enable control by PLC" to allow it to receive telegram data.
Hello I wanted to ask some questions about the G120C drive and the protection for it. I want to control a pump, with the motor rating of 5.5 kW...
199
Hello, I use a Siemens Sinamics G120C inverter in combination with a S7-1200 cpu. I use the Main Setpoint with the Providrive option and send...
735
Hi All, I had to replace one of my drives(SIEMENS G120C) in my conveyor system. the problem I'm having is the motor is running fine in manual...
1,237
Hello everyone. I have a project with Robot that I use, communication is provided by Profibus. I will add a conveyor to this project, for this I...
19
3,418
Good morning everyone, I have several Siemens projects, version 15, that each has 5 G120C PN drives in them. IT has requested the MAC address on...
1,181
