Yes it is. rs500logix is what we been using.
I need a program for a plastics extrusion line. Something with like extruders, and like payoffs, and takeups, and other things. I need it in 15 minutes. I'm too lazy to do it, so I'll just wait for you all to do it for me.
What's the weight of the door, the HP and speed of the motor, the gear reduction ratio, the total travel distance and the ambient temperature? How are you initiating an Open or Close command? What color is the PM light? Rotating beacon, flashing strobe, or simple pilot light? If it's a flashing strobe, what's the flash rate and are there any employees nearby with epilepsy?I need a program for a garage door opener that opens and closes in 5 seconds.Also that has a pm light that comes on after 5 cycles of the door.
It''s sad that you must not have checked and clicked on the "Downloads" section tab. There are several example/sample programs there just waiting for you.I need a program for a garage door opener that opens and closes in 5 seconds.Also that has a pm light that comes on after 5 cycles of the door.
