Gateway Ethercat - CanOpen
aand74
Dec 2005
Deinze
131
Does anyone have references for gateways Ethercat - CanOpen?
Where the master will have Ethercat protocol and the devices CanOpen.
The gateway should be both CE and UL certified.
Hi. Not sure if I understand you correctly.
The device below is an EtherCAT coupler. It communicates with an EtherCAT master.
https://www.beckhoff.com/en-en/prod...ls/ek1xxx-bk1xx0-ethercat-coupler/ek1100.html
You connect the above thing through an intgenal bus connector to the device below, which is a CAN open master, and the EtherCAT master can monitor and control CANopen field devices.
https://www.beckhoff.com/en-en/products/i-o/ethercat-terminals/el6xxx-communication/el6751.html
That gives you an EtherCAT to CAN open Gateway.
Thanks,
That was an option we were also considering.
If someone still knows alternatives we would be glad if you share them.
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
128
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
582
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
290
I have been looking to this and thought I'd ask for input from others before I take it in a wrong direction. The guy who used to set these up...
406
Hi, I recently installed 2 1783-NATR devices into two of our machines. The machines are pretty much identical, both having 1769- L24ER-QFC1B...
300
