Get IP address of compactlogix programmatically
Just display the four values separated by a period in the HMI.
In the HMI create a text object that uses an embedded variable for the left most value, then put a period. Then add the next value with another embedded variable. Then another period. Then the next value followed by a period. Then the right-most value.
That's how I would display it on the HMI. Note in my example below I added a return after each line so this would be easier to read. But they would all need to be on the same line to display correctly.
OG
OG
I would agree that if the work has already been done for a faceplate, this is a good approach.
If you are in a fresh or from-scratch environment, having the utility is handy so one's problem doesn't have to be re-solved.
I have my PLC and HMI connected to my local network over DHCP just like my laptop. I can upload and download including VNC to the HMI over wifi...
1,142
I'm trying to configure the IP address of my compactlogix l16er-bb1b in Studio 5000. I need to set it to a certain address as I'm planning on...
3,243
Hi, I have a compactlogix 5069-L330ERM processor, which has 2 built in ethernet ports. Both are currently configured and was completed using...
20
8,924
We have some vendor supplied machinery that runs on a CompactLogix 5370 (1769-L24ER-EBFC1B, FW rev. 28.011) that wasn't communicating with the...
2,926
Hello everyone, we want to change IP address for used compactlogix L23E-QB1B controller ,it assigned a IP address before, but this IP address is...
2,803
