get trouble with AB terminal block relay & timing Build simple panel with AB block re
HI folks,
I'm newbie and I'm trying to build my first simple panel with an AB 700 FSH Timming (120V input AC) & AB 700HTL1U1 terminal Block Relay (120V DC input, 120V output DC) & a DC drive with a Motor and a switch ^_^!
I got trouble when I wired everything up, start the switch and the Terminal Block Relay light on ... but flashing and make noise ! I double check the wiring diagrams and still don't understand why the Terminal Block Relay flashing and make noise !!
I think I used AWG#14 for everything (because that the only wire I got) But I don't think it's make problem right ???
OR ... something else I cannot figure out
Plz help
Thanks folks !
HI folks,
Plz help
Thanks folks !
