Yes, graph is modifiable.But I need to put our standart programs to plc that include graph program.Hence i need to convert that.If there is no way to do this I have to find another solution.
I don't understand what you need to do, can you give a specific example ?
If you want to open the graph block and modify it using the STL editor, open a non graph block, then use File>Open and select the relevant Graph FB. Once you have modified a Graph block using the STL editor, it will no longer be available in Graph.
Attached example block is a standart motor block which helps us to operate motors properly.I need to catch some values (remote, local, ready, feedback, fault, start ...etc) on block by scada.
Of course I can add these blocks to graph plc.But in this situation I need to connect necassery values to our standarts.
Therefore I asked if there is a way to convert whole program to stl or scl.
