Hardware configuration
panthripu
Mar 2004
228
The system data contains the hardware configuration , right ?
I have a PLC , siemens S7 400 which is working now.Due to some reasons i want to change the program in this project(project1)with another program.
I have another project(project2) where i have all the block without hardward configuration.
If all delete all the block from project1 excluding system data blocks and copy all the blocks from project2 excluding the system data blocks and use in project1.Is there any problem or I should take care of some other things.
Note : program in project1 and project2 is almost same. Only some modified logics are there in project2 written in better way.
Yes you can do what you suggest.
Some advices:
1. Make an archive of the actual system before you do the changes. Then you can retreive the original if something goes wrong.
2. Next time you want to do such changes, do a 'Save as ...'
and work on the new (or old) copy.
Kalle
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
458
Hello Folks, I am beginner to the PLC programming. I am working on a project which has Siemens S7-1516-3 PN/DP CPU, and ET200SP profibus based...
334
Hi everyone, I'm trying to learn how to make hardware configuration. I have an IM on profibus. I added the whole group (I dragged the marked taxed...
1,175
When I download a hardware configuration using the step 7, it first asks me to select the target module. Only option that is offered is the CPU...
1,200
Hello, Here i have a Tia Portal V11 Project that i wanted to fix but i cant take the device configurations from the device. So i just have to...
1,476
