helmholtz coupler tia portal
Welcome to the forum!
I think you will need to provide a little more details on what you want to achieve before you will get any help in the matter.
Afternoon all, So, i have an output that is being fired from 2 inputs separately. 1st input is a sensor, when something passes by it should...
323
Hello all! I have a PN Coupler connecting two PLCs, one on X1 and one on X2 and am able to transfer data using the IN and OUT configuration...
1,189
Dear experts i have an installation running with S7-1515 and a quite huge profinet network. i encounter an issue with a Siemens PNPN coupler...
2,175
For connecting to a Micrologix through a 1761-NET-AIC, the manual specifies that you should use "RS 232 Communication Cables Cable, Cat. No...
1,370
Hi. I'm struggling with configuration of PN-PN coupler 6ES7 158-3AD10-0XA0. The situation is as follows: I have 1 S7-300 PLC on the X2 part of...
5,031
