Hilscher DPM (Profibus Master) on AB Compactlogix.
shaunn
Sep 2005
Orapa
39
Hi All,
Has anyone had experience with the Hilscher DPM Profibus Scanner for AB Compactlogix?
I am attempting to use one to add a Profibus network to an existing AB system but cannot seem to get any config to download to the DPM - really frustrating.
Thanks,
Shaun.
Yes, it's connected to a CPU. The IO config has been set up as per the manual. However it faults straight away.
I am also having difficulty with the SYCON software. When I try to download a Profibus module, I keep getting an error 37 - User: Parameter Mode Invalid.
Surely you can download a hardware config succesfully without having the processor talking to it yet?
Hi All, problem solved! hats off to the support dept at Hilscher (who managed to respond eventually!)
In any case, it seems the problem lay with a missing softwar elicense that was supposed to be shipped onboard the DPM card itself. After manually typing in the key, it all seems OK now.
hi, all i have a problem with the download of applicaton on hilscher via comPro V2.225 , after download of application on hilscher Type: PKV 30-DPS , every thing is okay and two leds ready and run light , if i discouneted the power surce and reconected again the led " ERROR1" is light , i repeated these stepes again and the same case of Hilscher repeated that the led " ERROR1" .
pls. any body help me what i do about it
Working on a project with an existing Allen-Bradley CompactLogix PLC containing a Hilscher RIF 1769-DPM Profibus card which is the master. We need...
2,521
Does anyone use or have experience with the Hilscher NT 100-RE-DN Gateway? Tech support on Hilscher website for the North America region is two...
20
3,426
Has anyone got any experience with Ethernet-mpi IBHlink & tia portal 14 or newer I have it working fine in simatic manager but in tia, although...
1,924
Does anyone have experience with the Hilsher NL50-MPI Ethernet to Profibus adapter with Simotion Scout? I am using VMWare to run Windows XP with...
3,780
I'm using a Controllogix 1769-L24ER-QBFC1B and trying to setup a Generic Ethernet Module to communicate to a Hilsher NT50 ethernet I/P to...
6,744
