Hmi omron ns15-tx01b-v2
thiba007
Jul 2011
KUALA LUMPUR
Dear Experts,
Could anyone explain the how does Omron HMI address setting (like pushbutton, data record, data insert) will be writen in Omron PLC, I'm new user for Omron PLC. Most of time I'm familiar with Mitsubishi PLC. šŸ™ƒ
Thank you
Thiban
Not sure what model of PLC you are using but here is a link to the manual for the CP1L series, I believe that most models will use the same memory map.
https://assets.omron.eu/downloads/m...it_(including_cp1l-j)_operation_manual_en.pdf
Look at section 4.
CIO bits are the real I/O, however, any unused bits can be used as internal memory if required.
Data Memory "D" can be used for values either int, real etc.
Aux area bits "A" can be used as internal memory bits Etc.
So addressing I would assume in the HMI would be CIO0-99 inputs CIO100-199 outputs (this will depend on actual I/O on the PLC, any unused can be used for internal memory bits but should not be required) the equivalent in Mitsi is X for inputs Y for outputs.
A000-959 can be used as internal bits (Flags) these are equivalent to M bits in Mitsubishi, D is the same for both.
IM USING OMRON CJ2H with HMI NS15-TX01B-V2,
I WOULD LIKE KNOW HOW ADDRESS ON HMI WIL WRITTEN ON PLC.
EXAMPLE FOR MITSUBISHI PLC Q SERIES, D*** , R*** OR M*** CAN BE WRITE ON PLC
RUNG. PLEASE ADVISE THIS ATTACH SCREEN SHOOT
DEAR ALL, COULD ANYONE HELP ME ON THIS OMRON HMI THAT BEEN INSTALL TO A MACHINE.I COULDN'T SEE ALARM HISTORY. ONCE ONE ALARM RESET ITS AUTOMATIC...
1,773
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
301
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
891
Hey everyone, I'm new to this type of HMI and I have a couple of questions. 1) I'm creating a screen with text on it and base font is "DFNB-EN"...
426
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,215
