Home to Torque
angi
Jan 2010
us
361
Hi Guys
one question about motion control:
Is the "Home To Torque" a command instruction or a ladder code? this is my first time to try to use Home to Torque function, so I need some advices about how to use it.
thanks
Thanks Chit
the link you sent does not work, where can i find the add on instruction?
Just making sure that you are aware...one of the options when setting up an axis is to "Home to Torque Level". No add-on instruction required - no extra code required - just issue a normal home command (MAH instruction).
Under the Axis Properties -> Homing Tab, Select Mode:"Active" and Sequence:"Torque Level".
Under the "Active Home Sequence Group" you can set the homing speed and the Torque Level. Always start with a low torque level so you don't cause mechanical harm.
hi Kek
so what is the difference between the Addon instruction and this option?
thanks
I haven't looked at the Add-on to know what all it does. It may provide additional flexibility that you may desire or need. If you don't need it, I think setting up the homing properties to home to torque limit is simpler. I always take the simple approach when possible.
If you have over travel limits, these might need to be disabled to allow the servo to hit the mechanical limit. The Add-on may have this as an option. It may have some other abiltiies too. You'll need to play around with it to see.
hi guys
here is an application, one Axis A will follow Virtual Axis A move, what I want to do is every time when the motion start, the Axis will home to torque, and then I will redefine the position of Axis A and Virtual Axis A to "0", I will move the Virtual A using MAM instruction and gear the Axis A to the virtual one using MAG. will it work if I program like this?
thanks
yes.
Set your homing up for Torque level, then:
1. MAH axis 1
2. MRP Axis 1(position can be set thru homing), MRP Virtual Axis
3. MAG Axis 1 to Virtual
4. MAM Virtual
In this scenario, your virtual axis has no purpose since it's just moving your real axis. Nothing that a MAM on the real axis wouldn't do.
Hi guys, Has anyone used or tested the CIP Axis home to torque AddOn in the rockwell sample code library - 055818. A machine vendor wishes to...
7,871
Hi Everyone, I have a project involving a Beckhoff IPC with Twincat and a Yaskawa servo motor and drive. I'm trying to use the MC_HOME function...
517
I set up a Mitisubishi test system on the bench. Q03UDSPU Q173DCPU MR-J3-40B HF-KP43 HMI is a LS XP50 TTA/KP43 I am trying to use a signed...
402
I'm looking for some starter kits but there aren't so many on the market, so I'm thinking about buying individual components for my needs. I just...
2,508
We have a 5 Ton Rheem A/C unit at home We only run it in the Summertime, and sometimes in the Fall. It does have a habit of blowing fuses at...
18
2,551
