How Update Firmware Siemens S7-300?
rodrigoevaldo
Dec 2009
Brasil
Hi people!
I have a CPU 315F-2DP (315-6ff01-0ab0) and Micro Memory CARD
512KB S C-V3 ES:02 (6ES7953-8LJ11-0AA0).
The maintenance technician formatted (in the Windows) this card!
So how can I recover this card?
Otherwise, how can I update the firmware? You can update using a usb read SD CARD (or in the laptop SD CARD)?
Thank you.
Just for correctness, "firmware" is the term used for the basic operating system in the CPU.
You may have a chance to restore an image of an exactly similar MMC card by using the utility mentioned in this thread:
http://www.plctalk.net/qanda/showthread.php?t=5347
It shall be done in a regular flash card reader.
I have had good experience using it with an external card reader via USB. The internal flash card reader in my laptop did not work.
You need an exactly similar MMC card to make the image.
When OK, the S7 program has to be loaded again on the MMC card.
Hi folks, Just doing a project where we are having to get bits of data from various plcs (get & Puts etc) and adding a CP module into the mix...
1,822
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
463
Spoke to a few outlets including Emerson and some distributors. Apparently updating firmware on subsequent modules past the CPU still uses...
407
Hello everybody. I encountered a problem - I don’t know how to update the firmware on the Mitsu MR-J5-40G-N1 (ethercat) servo amplifier. My...
403
am having some issues with updating the firmware on a 1769-L35E,. The flash process will start and all the blocks are transferred, but at the end...
1,072
