I can't not upload program from NT20M (again)
smile
Mar 2004
bkk
36
I have touch screen model NT20M (Omron).
and use software NT version 2.33.
and use cable for interface(refer lower picture) between PC and NT20M at port no.1. (refer picture uppper).
What happen ? The software can't upload program from NT20M.
Please Hint to me.
Hello
In the NT touch screens you need to be in Transfer Mode to connect to your PC.
Did you switched the panel to this mode?
To switch to this mode you need to hold on two corners of the panel until the screen will change (in few seconds).
I hope I helped.
As well as being in transmit mode you will possibly have to change the port settings on the PC or laptop. I think its 9600 baud rate, 7 data bits, even parity, 2 stop bits. At least that worked with an NT31 and I can't remember where I got that info!Best of luck.
ArikBY said:
Hello
I hope I helped.
Mr.ArikBY
I don't understand, please hint me again.
Smile
As you see in the above pic press on 2 from 4 corners of the screen the panel will swicth to setup mode, then select transfer mode.
The touch screen is builded from matrix of switches see the 1st pic
Press on the two point I marked until the screen will change.
Please help me How to B&R 7CP476.60-1 upload program Backup and download which program should I use. Pvi transfer tool.? And how. Thank you
88
in our old machine we used beijer cimrex 41 need to take program backup. i tried it with information designer software through ethernet. ip...
84
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
167
Hi, I have received a request from customer to backup this PLC. If I upload the program from the PLC, does it include comments?
680
Hi. I came into a problem that was buried in my memory. I had a list of modifications to do on 2 RSLogix programs. So I tapped in the IP...
1,087
