Import ABB AOI into studio 5000
waqas
Mar 2023
victoria
I am having problem when importing add on instruction for ABB drive. I have attached the images here showing the rung is red after I entered the parameters into the AOI.
Please someone help me.
I've used quite a few AOIs, and I am pretty sure that none of them were imported as AOIs.
The vendor that supplied the equipment usually has example code, usually with the extension .L5X, and you import the rungs into your code so that you can rename the structures if you are going to use duplicates, etc and avoid your existing tags.
Do you have example code that you are importing rungs from, or are you typing things in manually?
I don't have any ABB drives to experiment with, so I can't try it myself.
If you go offline, you can hit the "Verify controller" options and it will list out an error message.
I'm trying to import a .prj file and I keep getting the error message: Project import error. i Any ideas how to get around this? Thanks.
78
Good day colleagues, I have a problem with a plc slc 5 since I export the tags to my factory program to load them into a panel view 1000 plus 6...
117
hey good afternoon ! I have a simple question, I need to import an Add on instruction to a controller that is in operation and cannot stop. Is it...
295
I am very familiar with Studio 5000 PLC programming. And I'm very familiar with C-More HMI programming. But this is my first time using a C-More...
316
I am trying to import addresses and symbols from a PanelBuilder32 application into the RSLogix 5 Address/Symbol database - however each time I...
537
