Import Tags to Cmore HMI from Siemens TIA Portal
Bmoore14
Jun 2016
ohio
New to TIA Portal... Is it possible to export tags from a data block in a format so that I can import into C-more HMI software successfully?
If not, what is the best route to take?
Thanks,
Brandon
I haven't worked with Cmore before, to know how they want to import things. There are really three ways to get things out of Portal:
1) You can export a DB as an SCL source. This probably won't be much help in an HMI package.
2) You can create a device proxy file for the PLC. However, I think this is a proprietary Siemens file type; I'm not sure if anyone else can read it.
3 (most likely to work)) You can simply copy the cells of the DB and paste it into excel. From there, you might be able to copy/paste directly to Cmore, or you could massage it into Cmore's import format.
Good day colleagues, I have a problem with a plc slc 5 since I export the tags to my factory program to load them into a panel view 1000 plus 6...
116
I am very familiar with Studio 5000 PLC programming. And I'm very familiar with C-More HMI programming. But this is my first time using a C-More...
316
I know tags can be im/exported from/to an L5K. Wondering if IO tags (Local:1:I) can be overwritten in the same way. For example, if I have an L5K...
777
Today I'm working with a MicroLogix 1400. I don't have the .rss file since we did not program the system. I was able to get the FactoryTalk file...
1,105
Odd behavior from Wonderware when I imported a couple windows. All the tags used on the windows already existed, but all of the tags came in with...
1,425
